Tom's Hardware > Forum > Homebuilt Systems > New System Build > Building a cheap system, should these parts work together?
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16811121004][/url]
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16813131329][/url]
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072][/url]
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16820104072][/url]
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16814121249][/url]
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171][/url]
-HEC 6K28BBX585 Black 0.8mm SECC Steel MicroATX Mini Tower Computer Case 585W Power Supply
-ASUS P5QL PRO LGA 775 Intel P43 ATX Intel Motherboard
-Intel Pentium E5200 Wolfdale 2.5GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor
-Kingston HyperX 2GB 240-Pin DDR2 SDRAM DDR2 1066 Desktop Memory
-ASUS EN6200LE TC1G/TD/512M GeForce 6200LE 512MB 64-bit GDDR2 PCI Express x16 Video Card
-SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X
CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
Sry for being such a n00b, this is just the first time i've built a computer that wasnt for me so I want the build to be quick and problemless
Sponsored Links
What is the purpose of this computer? The GPU you picked out will not be much better than integrated graphics, I would just get a G31 mATX board or maybe a G43 mATX board instead, like this one. That PSU is no bueno, get like a Corsair 400cx or PCP&C 370w Silencer and a cheap rosewill case. Change the ram to this, its going to be faster and you get more. You might want to pick up an aftermarket cooler for the CPU and do a light OC to improve performance, something like this could do the trick.
Message quoted 1 times
Message edited by xthekidx on 04-20-2009 at 04:07:04 AM
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
This computer is probably gonna be running some security cameras. I just picked out a cheap GPU because there were no integrated graphics. Awesome advice on everything though, thanks.
Reply to mike74
I dont want to spend that much on the RAM, how about this?
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16820231203][/url]
Reply to mike74
Thats fine probaby, but 4gb would be best. I don't know what kind of load running a security camera puts on a PC so I can't really offer too much more advice. If it will be a database for footage or something like that though you might want to get a large HDD for storage of data, like the WD1001FALS.
GTX 260 Core 216
Reply to xthekidx
Two gigs should be enough, I dont want to run Vista.
Reply to mike74
An ATX motherboard wont fit in a case designed for a m-atx mb
The m-atx case will just be too short for the bigger mb to fit .
http://www.newegg.com/Product/Prod [...] 6813157144
ASRock G41M-LE LGA 775 Intel G41 Micro ATX Intel Motherboard $62 on newegg
Cheaper than you original mb , fits in the case and you also save by not needing the gfx card .
You will be fine with 800 MHz RAM too . Intels c2d chips dont need more than that until you are seriously overclocking
, which I dont think is part of the plan .
That should be a very economical system to run too
Reply to Outlander_04
There are 918 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
