Best Case, Fans, Fan Controller for RED LEDs
Hi everyone,
Which case, case fans and external 5.25" or 3.5" external fan controller is best for a RED LED only i7-920 gaming PC? I am leaning toward a CoolerMaster HAF 932 case, Gigabyte EX58-UD4P mobo, CM V8 CPU cooler, so please base your suggestions on the default fan size of the CM HAF 932.
Also, which case is easiest to use towards this purpose, CoolerMaster HAF 932 or maybe an Antec 1200?
Thanks in advance for your input!!
5 answers Last reply
More about best case fans controller leds
  1. CM HAF 932 is fine.
  2. Do you want to manually control the fan speed or let the motherboard adjust the fans automatically?
    I would like to manually control the fans if possible, in order to have some control.
  4. Do you trust yourself to always remember to turn the fans up when you start a gaming session?
  5. Yes, I do. I already do it for my video card fan when I start a game. I also monitor GPU temps quite often while gaming. I have an old Dell XPS Gen 4 which doesn't allow me to see CPU and MEM temps, and the airflow of the case is not that good. I had to install an exhaust fan to help pull out hot air from the case.
    The HAF932 should provide lots of airflow and cooling...I can't wait to build this new PC. I will be posting a new thread in the "New Homebuilt" forum for input on my i7-920 build. I already posted one 2 months ago, now to update it as my budget has increased to $2000.
    -Misfit14
Homebuilt Cooler Master Cases Fan Controller Systems
