PSU connection doesn';t look right for MB
Last response: in Components
July 24, 2009 2:24:01 AM
Well, I got everything together and I try to turn it on, no luck. Seems I have to attach a 4 pin connector along with the 20 pin connector onto the MB in order to power up.
However, the PSU I have has a 20 pin connector. What's going on here?
The MB is Gigabyte GA-MA770-UD3
The PSU is OCZ 600W StealthXStream
More about : psu connection
July 24, 2009 3:11:20 AM
You should have another 4 pin, or an 8 pin (which is 2 -4 pins put together, and should slide apart) that you must plug in over beside the CPU.
m
l
July 24, 2009 11:12:29 AM
Ok, I found the issue.
Seems the PSU has the main 20 PIN and next to it there are the additional 4 pins labeled as '24'. And it slid right next to it and fitted perfectly into the last pins.
System lit up and is now running! :D
m
l
