yes, all your components can work in this mobo. Also is micro-ATX, but isn't a problem if you have the correct case and aircooling.
Cheers!
------------------------------If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
24.4cm x 24.4 cm...are the same of your current mobo.
Why you don't buy an ATX?
Reply to saint19
Usually yes, 'cause the new mobo have diferent components, then, diferent drivers too.
Reply to saint19
Reply to saint19
^Your welcome. Excuse me for my last response, but in the forum always recommend legal software.
Reply to saint19
