Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > [Solved] Sony motherboard replacement
Forum Motherboards & Memory : General Motherboard - [Solved] Sony motherboard replacement
Best answer from leon2006.
I have Sony Vaio Laptop model VGN-N21M and it has lost both of it's USB ports. One went a month before the other. Does anyone know what causes this?
Common cause of USB failure..... Electrical Overload.... Its common for users to use multiple devices at the same time and then use it as a charger for cell phones while supporting a USB-powered hard drive.
Worst that i have seen.... Shorted USB load or defective USB devices that overload the USB port.
Some notebook actually resets or go to power cycle to due to sudden drop in power supply voltage cause by the overload.
Its partly due to lack of education on notebook users that USB devices have limitations.
One Effective Solution:
Buy a powered USB Expansion port (Sold with Power Supply). This will protect the notebook USB devices from electrical overload.
For Replacement Motherboard:
Call Sony tech support
Go to Ebay and search for motherboard of the same notebook model as yours
There are specialty pc shops that caters for specific brands (surplus stores). In Texas are stores that sells Dell surplus parts... In CA there are stores that sell HP surplus parts.... Somewhere here in the US there has to be for Sony, Toshiba and other brands.
Sponsored Links
Mine went from mechanical damage. Hitting my mouse dongle on the side at weird angles too many times. The mouse works elsewhere but the laptop ports are now unusable.
Reply to ctbaars
Best answer
Reply to leon2006
Thanks, Mine has had a few bangs as well
Reply to bobdobalino
Just get an expresscard to usb adapter (or pcmcia if u dont have expresscard)
something like http://www.newegg.com/Product/Prod [...] 6839158015
Reply to rand_79
There are 1016 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
