Tom's Hardware > Forum > Homebuilt Systems > New System Build > Updated First Build. Please Help. Thanks.
Forum Homebuilt Systems : New System Build - Updated First Build. Please Help. Thanks.
Hello, below is my new updated build thanks to everyone whose been so helpful here. Please give me any last thoughts/changes I should consider. This is my first build so I don't know much. The rig is mainly going to be used as a graphic workstation and gaming. I've never overclocked before, but it's something I'd like to try if it'll better the performance of this build. The total comes to $670 including tax + shipping. I'd really like to get this down if at all possible to around $600. If anyone has any suggestions, that'd be great. I'd also consider switching to AMD if that'll make it cheaper. Here's the build. Thanks again for all the help thus far...
case: COOLER MASTER Centurion 534 RC-534-KKN2-GP = $49.99
http://www.newegg.com/Product/Prod [...] 6811119106
cpu + mobo (combo): GIGABYTE GA-EP43-DS3LR + Intel Pentium E5400 Wolfdale 2.7GHz = $159.98
http://www.newegg.com/Product/Comb [...] mbo.181203
cpu cooler: XIGMATEK Dark Knight-S1283V = $39.99
http://www.newegg.com/Product/Prod [...] 6835233029
video: XFX GS250XYDFC GeForce GTS 250 512MB = $129.99 (is it worth spending $15 more on the 1 GB version?)
http://www.newegg.com/Product/Prod [...] 6814150357
psu: OCZ StealthXStream OCZ500SXS 500W = $59.99 ($10 rebate)
http://www.newegg.com/Product/Prod [...] 6817341012
hdd: Western Digital Caviar Black WD6401AALS 640GB = $74.99
http://www.newegg.com/Product/Prod [...] 6822136319
memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 = $42.99 (will this work on the mobo I chose?) http://www.newegg.com/Product/Prod [...] 6820231122
cd/dvd: LG Black 22X (CAV) = $24.99
http://www.newegg.com/Product/Prod [...] 6827136152
fan: MASSCOOL FD12025S1L3/4 120mm Case Fan = $4.99
http://www.newegg.com/Product/Prod [...] 6835150070
Sponsored Links
cpu?
and if you go with an amd 720 BE with a mobo which has a 790GX chipset you could save about $60 while getting better performance in apps which can use the extra core and being equal or better in other apps.
Reply to Helloworld_98
The Total of the AMD 720be would be at $640 without a heatsink and youll need one with OC'ing.
Heres my Specs using your psu/gpu/optical:
wd black 640gb
http://www.newegg.com/Product/Prod [...] 6820231209
pi black 2x2gb
http://www.newegg.com/Product/Prod [...] 6819103649
amd 720be
http://www.newegg.com/Product/Prod [...] 6813131340
asus 770 atx
http://www.newegg.com/Product/Prod [...] 6811119137
rc-690
ocz 500w
gts 250 - see why your getting it :) cod wow for free, im getting the gtx 285 to get it for free :D.
lg x22 dvd
now thats at $640 without shipping and without any rebates.
adding the s1283v will bring it up to the price of the intel build you built. and you will need one of those if you OC.
Reply to fullmetall
I'd upgrade to a 780G motherboard though and downgrade the case to a 590 or antec 300 while using a silverstone psu.
There are 1023 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
