PSU Modular...Under $180 plz help
I need some PSU suggestions. I am planning on buying the following i7 rig next week and I am going to be using my 9600GT until the end of August. After that I plan on buying either a GTX 275 or a GTX 285 and using the 9600 GT as a physics card (Possibly add a second GTX card in the future for SLI). I currently own an EarthWatts 430 but I don't want to risk my rig with it. Will my current PSU be fine until I get a new GPU?
I only have a few requirements:
MODULAR ONLY
UNDER $180
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Thanks in advance. I appreciate everyones advice.
3 answers Last reply
More about modular under help
  1. Here are a few you can look at for yourself... :whistle:
    Thermaltake - Modular
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153072
    PCP&C - Not modular but good price for item
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703022
    Seasonic-Modular
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151067
    Antec - Modular
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371012
    The PCP&C really catches my eye, but its your choice :kaola:
    *edit- updated to all modular, cept the pc power and cooling
  2. Corsair 750w modular PSU
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
    I have a hx520w an a hx620w modular and never had a problem with them.
    single +12v@60A
  3. the corsair hx models are nice... i am looking for a psu atm to run my 8600 gts 512mb sli'd... i have a 1000w thermaltake toughpower now, but taht is gonna run my gtx 280 sli's :D
Power Supplies Components Product
