Tom's Hardware > Forum > CPU & Components > CPUs > E8400 water cooling
E8400 water cooling
Forum CPU & Components : CPUs - E8400 water cooling
hey all, have just recently had my TEC water cooler leak or condensate onto my gfx card, cant see a leak and idle much lower than ambient, i have installed 2 switches so i can turn off the TEC's fan and the TECs them selves, am unsure or ilde temps for this chip but im idling now about 38 deg c if i switch on fans and tecs it drop about 10 deg (when i play games ect.) is 38 fine for a not hot or cold day.
------------------------------ XFX 780I
E8400 WITH ZALMAN9700NT
XFX 9800GTX+
G.SKILL2GB
Sponsored Links
XFX 9800GTX+
G.SKILL2GB
Reply to im_just_jokin
Those temps are fine
------------------------------ Core I7 920 D0 @ 4.2Ghz
MSI X58 Pro-E
32GB SSD, WD Blacks In R0
Sapphire HD 5870's In XFire
Reply to PsychoSaysDie
I suppose You have Tec to cool water. In which case temps are probably OK.
I had different setup in days of Athlon XP. I had 260 W TEC to cool cpu and output of Tec was cooled by water.
Overclocked it was sub zero at boot, bios showing 0C and when under 100% load it was going to 8-10 C
Reply to ainarssems
There are 1018 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
