I have a problem with my new gainward gtx 295..every time the gpu reach 75-76° C the system freeze ( no blue screen, no errors, only the system plants..) and the only action to take is to hard-reboot manually ( from case ).. what can be the problem?
Here are some of my pc's specs:
GPU: Gainward GTX295 MOB: Asus P6T RAM: Corsair Dominator 3GB DDR3 1600 CASE: Antec Nine Hundred Two CPU: INTEL CORE i7 920 + Noctua NH-U12P SE1366 PSU: ENERMAX REVOLUTION85+ 850W
thanks in advance for the help
Message edited by Salv0 on 05-12-2009 at 10:52:33 PM
HI,
Last time i have system freeze like that the reason is my oc is not acurate. Just try to run your system without any tweaking or oc, return to the factory default , and do a fresh install of your driver.
If you are a user of windows7 maybe the graphic driver are not good.
The default fan speeds of most graphics cards is less than 60% of the speed they can run at. Using a program such as RivaTuner allows you to manually increase the speed at which the fan turns and therefore improve airflow around the card, lowering temperatures.
What OS? it is abnormal for a vista or windows 7 system to fail like that (if it is due to teh gpu) and not ahve TDR fire at least once. Are there display driver restarts in teh event viewer? Is soemthing else getting hot in tune with the GPU? It stands to reason that if the gPU is under load so is teh rest of the system. Make sure any OC is rock solid, and that the memory/cpu passes memtest as well. Without an error message its hard to say if it is for sure the GPU.
Though I have had hard locsk without BSOD becasue of other components related inone way or another to an OC.
No OC is applied atm ( I have currently the default bios settings, no XMP ) Memtest is passed with no errors. Cpu reach only 50° with 20 cycles of LINX
Dunno other components..what else have I to check?
Message edited by Salv0 on 05-12-2009 at 11:29:23 PM
Update: I reinstalled drivers as suggested..now when gpu reaches 79° I have the freeze O_o all this is so strange lol This makes me think that could be a problem of other component
Message edited by Salv0 on 05-12-2009 at 11:55:49 PM
The auto fan speeds will not be as fast as if you manually set the range with RivaTuner. For example, on my 8500GT the auto fan speed never goes over 50%.
I tried 2 mins ago to run furMark with fixed 80% fan speed..it freezes anyway then I tried to disable the onboard sli, but again freezes..so I think this is a flawed card..i have to use the RMA ç_ç
Message edited by Salv0 on 05-14-2009 at 03:32:13 PM
i have the same problem with freeze on games and 3DMark Vantage with vista 32
i dont now the gpu temp but to correct this problem i have disabled the dual gpu option in the nvidia control panel.
Yeah but that is not a solution! 3DMark score now is 12000!
i have installed the nvidia latest 185.85 drivers and update vista with a lot of KBXXXXX and now 3DMark run with a 22000 score but the first game i try (Tomb Raider Underworld) freeze after 10 minutes
Message edited by labdogz on 05-19-2009 at 11:44:02 AM
