Hey guys/gals.
My mobo is a Gigabyte GA-X58-UD3R.
RAM is Kingston.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139267&Tpk=KVR1333D3N9K3%2f12G
The RAM is running @ 1066, but I wanna get it to the stock 1333. Memory doesn't support XMP(at least I don't see that it does) so I need to adjust manually. I know I need to go into "MIT" in the BIOS and adjust the "BLCK" settings. Not sure *what* settings need to be adjusted though? This is my first time messing with this stuff and I don't wanna break anything.
Here are the specs from the RAM to run @ 1333:
9 (CL)
9 (tRCD)
9 (trp or tRCP)
27 (tra, trd or tRAS)
1 (CMD)
1.5 Voltage
Any guidance would be greatly appreciated. Thanks for your time...
RAM is Kingston.
9 (CL)
9 (tRCD)
9 (trp or tRCP)
1 (CMD)
1.5 Voltage
