Solved
Problems with 6950
Hey all,
I have a sapphire 6950 that is great but at the same time has some problems... its stock with the newest drivers (haven't flashed it to a 6970 or anything) and it gets a 1220 heaven 2.1 score (can run the benchmark over and over), and will run furmark as long as i want it to, but when i play WoW it randomly black screens till I have to manually restart, and when I try to play Starcraft II it blue screens (something about driver issue). Just was curious if anyway else has been having this problem or something similar.
Thanks !!!
O, and I also RMA'd my first card thinking it was a bad card but the second one does the same exact thing.
10 answers Last reply Best Answer
More about problems 6950
  1. What drivers are you using 10.12? if so you may want to try 10.11a.
  2. every link i find for the 10.11a drivers says its for the 5870.... is that what I want to use? thank you for the quick reply by the way Davcon
    Here's a proper link and you're looking at the old regular mainstream November 2010 CCC suite.
    This link is legit but keep in mind these are beta drivers leaked on January 13/11.
    They are very hard to find at the moment.
    http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=18&go=giveme&dwn_id=1352
    Also out of curiosity is your system new?
    Have you had bsod's before the new card.
    Have you Memtested your ram before?
    Always completely uninstall previous gpu drivers before installing new ones.
    You should have usefull free apps like CCleaner on your rig as well as DriverSweeper.
  4. thank you with the new drivers I have only had one black screen and it was on WoW (I think Cata is still rough). the computer I am using is as new as the card (built it right around christmas) it is as follows:
    AMD 955 BE OC to 3.91 using the Cooler Master 212+
    AsRock Deluxe 4 motherboard
    4 Gigs of G. Skill ripjaw 1600 currently only running 1333 (more stable for cpu OC)
    7200 rpm HDD with Windows 7 64 pro on it
    1000w kingwin bronze certified PSU
    all inside a cm 690 II advanced case
    as to the Memtest I havn't used that exact program, but I have ran the PCmark mem test multiple times with no problems.
    I have never used driversweeper (will try it out) and do use CCleaner
    Thank you ! :)
  5. O and about uninstalling drivers before installing new ones.... I've just been using catalyst to install... Do I actually need to go into the driver manager and delete the drivers before i install new ones?
  6. Best answer
    In short yes!
    I've been using Ati gpu's since 2002 and deleting ATI/CCC in add/remove programs delivers the best results.
    Now here's what i've been doing for the few years.
    After uninstalling in add/remove
    I use DriverSweeper in safemode
    I'll guarantee there will be a long list of Ati renmants.
    Check of Ati
    Analyze and clean
    Restart normal mode
    Install latest drivers for your gpu
    This method has provided the best results for me .
    Btw found a revised 10.11a download
    http://www.mediafire.com/?zoqb8nzmsbheeg6
  7. davcon said:
    In short yes!
    Check of Ati
    Analyze and clean
    Restart normal mode
    u dont need to do this, u just need to installa new drivers over the old one, thats it
  8. Best answer selected by oldmud.
    nThanks for selecting me as best answer!.:)
    nI now realize a had a typo drivers were 11.1a and the official Amd release is now available.
    nI just installed them using the method i described in this thread.
    n
  10. Ya the new drivers improved my 6950 heaven score quite a bit... Still having a few problems with my RIG but they should be fixed here after my new RAM arrives... Thanks again!
    (I was almost tempted to just get a 570, you saved me some money)
Graphics Cards World Of Warcraft Overclocking
