Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Acer X233H LCD resolution problem
Forum Graphics & Displays : Graphics Cards Acer X233H LCD resolution problem
Hi,
I have problem setting right resolution for new LCD Acer X233H with SFF Dell GX-280 with
IntelĀ® 82915G/82910GL.
LCD info page says that it should be 1680-1050 (expected) but on my PC I can do only 1400-1050.
As I've check my video with 128M should support up to 2048x1536 at 85 Hz maximum resolution ( from link at the bottom).
And most interesting part that I could get this 1680-1050 resolution on another LCD Samsung T220. I could see this option both in Property and Display Control screens.
In both cases I used D-sub with windows XP.
Anybody can suggest how to get it fixed, should I play with drivers.
I also played with Acer LCD setting with no success.
Tx to all
Dai
reference links:
http://shopping.msn.com/specs/acer [...] 5ms-1920-x
http://www.intel.com/support/graph [...] 012579.htm
Reply to dainova
The issue is not the monitor but Intel's GMA 900 integrated video controller.
See below link as an example of Googling "GMA 900 1680 x 1050 issues":
http://forum.eeeuser.com/viewtopic.php?id=31602
One of user posted a solution is to install the latest GMA950 driver. Select 1680x1050 and then click apply.
Good luck.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
- 0 +
I've installed winxp_14324.exe driver intel driver depo, and still have problem only on this particular acer lcd, very same PC works 1680x1050 on samsung T220.
Don't know what is wrong.
Tx, Jaguar
Dai
Reply to dainova
- 0 +
If you really can't get it fixed, you can get a real cheap PCI-e low profile video card. Your Dell GX-280 has a PCIe slot correct.
http://www.newegg.com/Product/Prod [...] 6814162026
Reply to AKM880
There are 1883 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help appreciated
By 2fast4thetown_down, 4 hours ago:
If you have a 400 or more psu you should be fine it seems to be compatable just look at...
Best offers
Top experts
