Hy guys !
I need some advice please i want to build my first gaming rig and after some reaserch i got
some basic components (need only the box no pheripeals / no GPU / no Optic Drive ) :
- Asus - ATIradeon 4850HD - allready bought-
Stuff i think of buying:
Case: Antec Three Hundred
Mobo: Asus M3A78 PRO
PRoc: AMD Phenom II X4 940 Black Edition 3.00 GHz skt AM2+
RAM: Corsair 4GB DDR2 1066MHz CL5 Dominator Dual Channel Kit
PowerSource: CoolMaster Real Power M620
Hdd: Western Digital 640GB SATA-II 7200 rpm 16MB Caviar SE16
Proc Cooler: Cool Master V8
Now some questions :
1. Will this rig work or are there some hardware incompatibilities ?
2. If it works do i need to update mobo bios so it works with the CPU ?
3. Is the power supply any good for this rig ? Can i use ( maybe in the future ) 2x ati4850HD in Crossfire ?
Any sugestions for some other power supplies that work with the antec case ?
4.Is the mobo any good ? Does it Choke the power out of the CPU ?
5 Do i need the CPU cooler or i can go with the box one ? Can you guys recomend a good cooler ( some mid range price not the
extreme ones ) ?
6. Do i need to tweek the ram so it works at 1066 ? i heard it works at 800 and you need to set the
voltage manualy to 2.1 to get them at 1066
7. Whats the deal with Raid HDD ? do ineed 2 identical Hdds to put them togheder ? Do you guys recomend that or is it
too unstable ( crashing and stuff )
Remeber - i allready bought the Gpu 2 months ago
thx
extreme ones ) ?
thx
