this one is locally available and I m on a budget.
Give your views.
BTW my specs are
CPU:E7300 at 3Ghz
Mobo: Gigabyte 945GCM-S2L
PSU:Mora 400w 18 amps on 12v rail.
Sony DRU810A DvD Writer
WD 250GB + Seagate 40GB
Etc etc.......
But I saw in a youtube video that 9800GT is the winner.
Okay I will agree with you, But a 30$ price difference is there between the two(In the market where i will be buying the card).
Hey just one more question before I get the card.
WIll this card fit in my case?
The case dimensions are:19.1 X 8.5 X 17.8(inches) or 48.5 X 21.5 X 45 cm.
For the 4770, it is equivalent to a quieter and cooler version of the 4850. The 9800GT is just about equal with the 4850. Depending on the what resolution you want to play in and what game you want to play (some games are picky with ATI and Nvidia), I would recommend the 4770 for 1650 x 1050 or lower, it will dominate the 9800GT there, but any larger resolutions and I think the 9800GT will win. I'm an ATI boy, but I won't be biased, but my girlfriend's 9800GT can play all the games she wants maxed out (mostly mmorpgs and Left 4 Dead) on 1680 x 1050 resolution. A 4770 can do the same, but will have a better cooling solution and consume less power, but only because it is a recently released card. It will also sport GDDR5 instead of on GDDR3, but other than that, both cards are almost equal in most games.
