Vaio Sound Driver problem
Hello,
I have been trying to install a sound driver to my asian Sony Vaio after I installed new Windows XP Pro, however it resulted in semi-crash. As soon as I try to play a sound including a Windows opening track, it becomes freezed in few seconds and computer becomes locked. After I uninstall the driver, it becomes ok again. I suspect that devices stack for some reason. Any ideas/suggestions for this problem? Btw I have SigmaTel Soundcard and vaio model is VGN-SZ15LP. Thank you!
3 answers Last reply
More about vaio sound driver problem
  1. After I try to install in safe mode, the installer wanted a sthda.sys which I couldn't find. I searched the web and they said it was supposed to be at system32 file at Windows folder. It was not there. Any ideas how I can get it? I believe this will solve my problem.
  2. You need the SigmaTel High Definition Audio Codec. I don't think it works without it...
  3. I tried it. The problem is;
    if the driver is installed(correct one) ===> cpu works at %90+ rate and No Sound
    if the driver is not installed =========> cpu works at normal rate and still no sound.
    Audio Device is forcing CPU to work at veeery high rates if the driver is installed. Any ideas about it?
Drivers Sound Driver Windows XP
