Okay guys I have a question. My girlfriend's computer won't turn on. She has a Gigabyte P45 motherboard with an Intel Q6600 CPU, a XFX PVT98GYDLU GeForce 9800 GT 512MB 256-bit GDDR3 GPU, 2x2GB of G.Skill DDR2 1000mhz RAM, 640GB HDD, and a DVD burner in a Raidmax case with 3 fans. Her power supply is an Antec 500W PSU. Upon powering the system, the LEDs on the motherboard light up for a second and the fans for the CPU/case move for a second and then it shuts down. She's only had it for approximately 6 months and everything is stock clocked, no overclocks nor mods(except for Arctic Cooler 7 CPU fan) in any part. Does anyone have a solution to our problem? Thanks in advance.
**UPDATE: So testing one part a time from just mobo+cpu, then adding one stick of RAM, the system worked perfectly. As soon as the 9800GT was added in, the system just shuts down right away. When attached to motherboard and unplugged to power supply, 9800GT seems to at least partially function because it has a red LED indicating lack of 6-pin power connection. After opening the metal plate on top, the fan has stopped squeaking and I've removed most if not all the dust inside.
**So the GPU was faulty. Sending it back to XFX for a replacement. Thanks for the help.
