I found this offer for a barbone starter kit. Tell me if you think it is worth it? Checkout the CPU! This is what I was drawn to the CPU.
XFX nForce 680i LT SLI Motherboard - OEM - Qty: 1 $99.99
Intel Pentium D 965 3.73 ghz Extreme Edition Processor - Qty: 1 $199.99-----(at least $500)
OCZ SLI 4096MB PC6400 DDR2 - Qty: 1 $44.99
Hitachi 7K1000.B Hard Drive - Qty: 1 $89.99
Ultra X-Blaster ATX Blk Mid-T Case - Qty: 1 $49.99
Ultra LSP550 550-Watt Power Supply - Qty: 1 $69.98
ALL FOR ---------------------------------------$399.99
Would this be better than what I am running right now?
Tower--Ninja (478x260x540mm)
ASUS Crosshair 941 pin motherboard (Nvidia chipset board)
AMD Athlon 64 x2 dual core 5600+ 2.91 ghz
XfX Geforce 9800 GTX + 512 DDr3
ValueSelect---4 gb
372 gb harddrive
Rocketfish 550w power supply
Vista 32bit
Any input would be greatly appreciated.
thank you
ValueSelect---4 gb
372 gb harddrive
Vista 32bit
thank you
