Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will I need a PS extension cable for this case?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will I need a PS extension cable for this case?
I recently bought an Antec 1200 case.
Before I pull apart my current build, does anyone know if my PSU will have long enough cable for this tall case?
Here is my current PSU. (I plan on upgrading at the end of the year)
http://www.newegg.com/Product/Prod [...] ake%20430w
Thanks in advance for any help.
Message edited by Rocket254 on 07-29-2009 at 06:45:21 AM
Sponsored Links
If you are planning on hiding the PSU Cables using the Antec 1200 cable mamagement case system. Then yes you will need one. But if you do not mind the PSU 8-pin Mobo power cable running across the length (Bottom to Top) the no if cable length is 11" long.
You will also need this 8-pin Power Extension cable. It is needed on most Bottom mounted Psu cases.
1ST PC CORP. 12" 8-pin EPS extension cable Model CB-8M-8F - Retail $7.99
http://www.newegg.com/Product/Prod [...] 6812706004
Message edited by Yoosty on 07-29-2009 at 07:07:44 AM
Reply to Yoosty
http://www.newegg.com/Product/Prod [...] 6812198023
Is this a decent extender for the 20/24 pin cable?
Also, and this is an ignorant question, but what do I need the 8 pin for?
I just checked the PSU and I am using a 4pin cable for the +12V to the mobo.
Wouldn't I need this:
http://www.newegg.com/Product/Prod [...] 6812706005
Message quoted 1 times
Message edited by Rocket254 on 07-29-2009 at 07:48:25 AM
Reply to Rocket254
Yes on the 20/24 pin extender. Any cable that is sleeved is a good one.
My mistake on the 8-pin power extension, been dealing with Mobo's that use those only now. Sorry about that.
Reply to Yoosty
No problem.
Thanks for your help. Cables are on the way.
Reply to Rocket254
There are 778 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
