Hello,
Right now I have 3 case fans, a 120mm front intake, 120mm back exhaust, and a 230mm side fan. All 3 fans have a 4-pin molex male and female connector. I was wondering if a fan controller would be able to handle these fans or if it would burn out? I have heard that some fan controllers go out with more than one 120mm fan, so yeah..
Would it be better if I just hook up my fans straight to my PSU? and if so.. would it be ok to just attach them all together and then onto one 4-pin connector on my psu or should I separate them?
Here is my case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
and my psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
Thanks in advance for any help ^^
