K here is what im looking at to get for my new build
Motherboard - 140
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128359
CPU 206
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115037
Memory 71
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231166
Case 50
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119115
Hard Drive 88
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136218
PSU 75
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341012
Total = $630 most im looking to spend on these parts would be around $600 maybe $650
I have futureshop gift cards and these are the parts im looking to get from there
DVD/Blue Ray Drive
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10097099&catid
I was wondering if this would work with my build
Graphics Card
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10118965&catid
Or
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10114872&catid
I was wondering which one is the better one and also would they work with my build
This is my build and im going to be using it for gaming and websurfing ect.
I have a monitor and mouse/keyboard already
Was wondering what would be the best OS to use and which one to get im looking to get it off newegg.ca so which would be the best one to use plz tell me
Also will these parts work with eachother because im going to order these parts and i need to know if they are compatible
also any suggestions would be greatful.
THX.
Motherboard - 140
CPU 206
Memory 71
Case 50
Hard Drive 88
PSU 75
DVD/Blue Ray Drive
Graphics Card
Or
THX.
