the hdd led, power sw, reset sw, and power led cables are difficult to undestand.
i read the mobo manual and it says the place where my hd led should go, wich is in these 2 pins next to each other, but my 2 pin led switch (thats connected to my case) is 1 pin apart (3 holes, middle one unused) so how do i plug it into my mobo?
seccond, for the power and reset buttons, instead of positive and negative they just say the function (reset) for one pin, and ground for the other, wich ones wich on the cables?
