How remove write protect in usb flash memory silicon power
  • Flash Media
  • USB Flash
  • Power
  • Memory
  • Storage
Last response: in Storage
Anonymous
a b } Memory
a b G Storage
December 9, 2010 7:26:05 AM
Hello,how remove write protect in usb flash memory silicon power
More about : remove write protect usb flash memory silicon power
a b G Storage
December 9, 2010 11:06:05 AM
If the drive has a slider lock on it's side, set that slider to Unlock.
In my Computer. right click on that drive's letter> Properties> Security>Change the permissions for Write to Allow.
May 16, 2011 4:27:38 PM
May 18, 2011 3:21:55 PM
Remove USB Memory Stick Write Protected:
How to remove a write protection from your USB memory Stick
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (F8) key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Note:
Before removing USB from your computer, Always remove it safely by going into to my computer then right click on USB and click eject.
November 10, 2011 10:52:16 AM
i also have this problem but i tried doinfg this command prompt and it says cant format because of write protection...what do i do now plsssss assist....
March 19, 2014 5:52:26 PM
If the problem is persistent with the drive and you still can't copy files to it or format it after:-
1- You tried removing read-only permission from the drive properties
2- You tried formatting from Windows
3- You tried formatting from CMD using DISKPART
4- You tried editing the Registry solution (for WriteProtect word)
5- You tried the different free online tools like HDD LL Format tool and HP Format Tool
Then your drive is corrupt and needs the internal chipset S/W to be flashed, i.e. repairing the USB software. The steps below will lead you to get a small program to run on your USB memory-stick which is specific to your MANUFACTURER (make) and PRODUCT (model). If you don't want to go through the headache of the manufacturer's technical support then do it yourself as follows (which I source from here):-
1- Get Chip Genius portable application from here which you will use to find the VID and PID of the USB stick chip.
2- Search for the tool to repair your USB stick S/W from FlashBoot website . Search using your VID and PID from the previous step.
3- Search on Google for the name of the application you find in the "UTILS" column in the page from step 2 and the first link on Google Results (usually) will take you back to the FlashBoot website to download the utility to get your USB drive repaired.
It worked for me for my Kingston Data Traveler flash drive. It didn't work with all the common options for fixing the USB drive having "write protected", but the above solution I found after hours and hours of searching online and asking my computer-geeks colleagues.
Hope this helps! :bounce:
March 27, 2014 6:10:04 AM
Samy, thank you very much. I don't know how much your post helped the others, but it helped me for sure with a Silicon Power UDB 3.0.
March 30, 2014 3:14:37 PM
Can someone that has successfully been able to use this program please help to explain to me how to use the program "FlashBoot" I have downloaded all the files but i can't seem to get it to recognize my usb drive. i dont know if i have to go into the setup because what i have been doing is trying to see if it would auto detect it.
here is my usb drive settings from the Chip Genius software:
Kingston DT101G2 64GB
Description: [E:]USB Mass Storage Device(Kingston DataTraveler 2.0)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0930 PID = 6545
Serial Number: 001CC0EC3450ED3167140119
Device Vendor: Kingston
Device Name: DataTraveler 2.0
Device Revision: 0100
Manufacturer: Kingston
Product Model: DataTraveler 2.0
Product Revision: PMAP
Chip Vendor: Phison
Chip Part-Number: PS2251-61(PS2261) - F/W 05.09.53 [2011-11-02]
Flash ID Code: 983A9992 - Toshiba [TLC]
after that i downloaded the "AlcorMP_AU698x_RT_v1.0.0.14_L0117" utility but i don't know how to use the software and the help file is in Chinese.
Here is a pic of the program i cant get it to auto detect
please help, thanks
March 30, 2014 4:36:28 PM
any ideas ??
June 14, 2014 1:03:44 AM
this not help so much...only the redundancy iv'e seen...
