Power Supply questions
hey im building a new gaming computer and i wanted to know what kind of power supply i should get. my build is:
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Antec EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
GIGABYTE GA-EP43-DS3LR LGA 775 Intel P43 ATX Intel Motherboard - Retail
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
im using this computer for pretty much only gaming but i want to stay as cheap as possible but still have good quality. i was wondering what kind of power supply i should get and if there are any that are a good price. thanks
6 answers Last reply
More about power supply questions
  1. the antec 650w is a good one.
    Others would be:
    Corsair 650w/750w/550w
    Ocz 550w/700w
    Ultra 650w
  2. do you have any specific power supplies that would be good for this build, thanks
  3. id recamend anything over 600w maybe more if you want it to last a good few years. i find corsair are very reliable.
  4. The Antec you selected is a very good Power Supply
    Another very good unit
    CORSAIR CMPSU-650TX 650W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
  5. Well as you will not be able to crossfire, I feel a good quality 550W is more than suffice for that setup...
    Best would be a corsair but the 550VX is nearly the same price as the Antec...
    So go with this...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
  6. I'd stick to the Antec you selected. I have never had a bad Antec PSU ever. Remember when in doubt go for Overkill (applies to PSU's).
New Build Power Supplies Systems Product
