Really, I'm not crazy...Help
G
Guest
Guest
Archived from groups: alt.games.the-sims (More info?)
So where do I put the downloads for the Sims 2? I read all kinds of things
about a download folder, but there isn't a folder in my Sims 2 drawer that
says downloads. IF someone could let me know, I would be eternally
greatful!!
Thanks!!!
Huggggggggs!
Beckie
ali
134
> greatful!!
> Thanks!!!
> Huggggggggs!
> Beckie
You look under My Documents/EA Games/The Sims 2. If there is not a
Downloads folder in there then you can create it yourself. Mine did not
come with the downloads folder either, I had to do it myself.
Ali
G
Guest
Guest
> greatful!!
> Thanks!!!
> Huggggggggs!
> Beckie
Try starting with My Documents. Then EA Games, then The Sims, and I'll
bet you can see one there.
It ain't in program files. It's tricky.
-georg
G
Guest
Guest
georg wrote:
>> things
>> that
>> greatful!!
>> Thanks!!!
>> Huggggggggs!
>> Beckie
I never actually had a downloads folder, so I made one. Works for me.
--Cuth
G
Guest
Guest
WooHoo!! I found it!!! THANK YOU ALL!!!
hugggggggs!
Beckie
"ali" <babaonthenet@hotmail.com> wrote in message
news:87adnfxGWf-hZsPfRVn-sw@comcast.com...
things
that
> > greatful!!
> > Thanks!!!
> > Huggggggggs!
> > Beckie
> Ali
G
Guest
Guest
No the game doesn't create one automatically - you can either make one
yourself (make sure you spell it right Downloads with a capital D and an
's') or create one using Bodyshop or Homecrafter. Fire up Bodyshop, make a
sim, exit - e voila a Downloads folder! You can then delete the sim you
made if you want.
This, BTW, is a fool-proof method if creating one manually doesn't work.
Best wishes
Maxon
"Cuthbert Gurdlestone" <chgurdlestone1154@earthlink.net> wrote in message
news:425F3B79.5090700@earthlink.net...
> georg wrote:
> >> things
> >> that
> >> greatful!!
> >> Thanks!!!
> >> Huggggggggs!
> >> Beckie
> --Cuth
