Sound Card Error
Forum CPU & Components : Sound Cards - Sound Card Error
I am receiving the following error. c:\drivers\nc6910\03_adisoundmaxhdaudio\i386\DevSetup.exe. Since yesterday, I no longer have sound coming from my computer, I tried to repair the device, it said nothing was wrong, then when I ran a test on the sound card, I received the error.
Sponsored Links
Well that "c:/drivers" seems weird because they should be in Program files somewhere
either in the sound card's directory or in windows/system32 if onboard sound , and the i386 directory is a windows install directory,I think that you either might uninstall the audio drivers,reboot and shut down the computer a couple of times and then reinstall the audio drivers again ,, or if that don't work reinstall windoze right over it all,if it IS a sound card can you not test it in another computer..:)
------------------------------ When you obsess on your enemy,,
You become The Enemy...
Reply to dokk2
Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Card Error
There are 1410 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
