Tom's Hardware > Forum > CPU & Components > Sound Cards > Connecting Car Audio Components to PC/TV
Forum CPU & Components : Sound Cards - Connecting Car Audio Components to PC/TV
Hello all, I'm a new member - and I'm not exactly sure where I should post this question, or if I will get any responses to it!
As the title says, I'm interested in hooking up a subwoofer and a couple speakers from an old car setup for use with my computer, or with my television.
I'm more concerned with hooking the subwoofer up by itself, but any help would be great.
Here's the components I've found around my house:
1. Rockford Fosgate 10" Punch Subwoofer / RFZ1410 / 4 Ohms / 200 Watt
2. Pyramid Gold Series Subwoofer Electronic Crossover / Model CR-66
3. Pyramid Power Amplifier / 240 Max Power Watts / PB175 / 120W x 2 Channels (I have two of these amps)
4. Universal Installation Wiring Kit (Various gauges of wire and that kind of thing)
5. Stock Chevy Impala (year 2000) 6" x 9" Speakers / Unknown Watt / 4 Ohms
I've been trying to read up on this process, and I'm not entirely sure if I can (or need to) use the amplifier at all... I've found a computer power supply of 350W, which I hope will be able to run the subwoofer on its own. The problem is I don't really know how to convert the AC into DC for the 12V audio equipment. Also, I don't know how to hook up to various inputs (such as the RCA from my television, or 3.5mm from my computer?).
I was hoping to build some kind of enclosure to house all these components so I can carry it around from place to place. But right now I'm just trying to get my head around how to properly combine all these components into a working sound station.
Any help or tips would be great,
Thanks!
Sponsored Links
delete
Message quoted 1 times
Message edited by coukos34 on 08-01-2009 at 05:46:24 PM
Reply to coukos34
okay thanks.
well, update to anyone interested...
i got a hold of a 350W power supply and clipped the main power plug so that it would turn on. that worked fine.
next, i hooked it up to my amp to get power to it. i powered up again, the supply started, and the green light on my amp turned on. that worked fine.
next, i hooked up my sub to my amp and turned everything on again. everything turned on including the sub. that worked fine.
now this is where my problem starts. i turned it off for a few seconds, and i tried to turn it back on. nothing happened. i have no idea what the problem is. i disconnected everything and started over from the power supply, and now i can't even get that thing running on it's own.
does anyone know what's going on?
Reply to thefuturism
- 0 +
the pc power supply dont quite work that way . not like a regular power supply . it has a momentary power switch and the os helps it turn off . to do what you want to power car equipment--- i think you will have to convert it to a self contained power supply . try these sites to see if they help you ------------ http://web2.murraystate.edu/andy.b [...] supply.htm and http://case-mods.linear1.org/case- [...] stified/2/
Reply to ronman2
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
