Tom's Hardware > Forum > Motherboards & Memory > Asus > Win7 RAM upgrade help/questions - Help?
Forum Motherboards & Memory : Asus - Win7 RAM upgrade help/questions - Help?
I am upgrading my PC for the upcoming Windows 7 release.
Currently, I have two, 1 gig sticks of this ram - http://www.newegg.com/Product/Prod [...] 6820220144
My motherboard is the P5B Deluxe Wifi AP. http://www.newegg.com/Product/Prod [...] 6813131028
I would like to upgrade with this RAM - http://www.newegg.com/Product/Prod [...] 6820145184
Now - my question is, do I simply just replace the old ram to make 4 gigs? Or do I just put the new ram in the yellow slots (where old ram was) - and put the old ram in the black slots to create a total of 6 gigs?
Message edited by Shankopotamus on 10-17-2009 at 12:20:15 AM
Sponsored Links
I really wish I knew someone with a bit of knowledge on Mobo's and memory. There's just -so- much excess information when I google something like this.
Reply to Shankopotamus
Just add the new ram, but make sure it's the same speed brand as the 2 1gb sticks, for 6gb total goodness, this is the memory you want, enjoy.
http://www.newegg.com/Product/Prod [...] 6820220269
Reply to reconviperone1
Thanks for the advice! So, it has to be the same brand? Didn't know that.
I've read some things about the yellow or black slot...
Do you know anything about that? Put the more powerful sticks in the yellow? Weak in the black?
No that just keeps it dual channel, the memory sizes have to go in corresponding slots, i.e the 2 2gb in one color and the 2 1gb in one color, so you can just add the 2 2gb to the empty slots.
Thanks a bunch.
I just wish it wasn't so darn expensive. Used to be a lot cheaper....
Yeah, i got 4gb of 1066 back in the summer for 45 bucks, a year and a half before that i payed 200 dollars for 2gb ddr 800, so it's not to bad, and worth the investment, im running 8gb, and it's nice.
There are 821 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
