Now - my question is, do I simply just replace the old ram to make 4 gigs? Or do I just put the new ram in the yellow slots (where old ram was) - and put the old ram in the black slots to create a total of 6 gigs?
Message edited by Shankopotamus on 10-17-2009 at 12:19:17 AM
Tell us the specifications of your RAM, the link don't show you currently RAM.
------------------------------If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
You can use your old RAM, BUT the voltage coulde be a problem, your current RAM is to 2.2V, and the other is to 1.8V.....With more low voltage is better, so put your new RAM in the yellow and the old in the black, BUT in the BIOS configure the V RAM to auto.
Reply to saint19
Message edited by saint19 on 10-18-2009 at 04:42:36 AM
Reply to saint19
