I have never built a system before. But I have replaced HDD / Ram / Video / Audio cards / reformated drives / reinstalled OS and Apps.
I am concerned that the combo below will NOT power all the fans in the system.
1.) Will it power all the fans?
2.) Do I need an additional fan controller?
3.) Will I need fan cable extensions? 3 or 4 pin cables?
Mobo: $370
ASUS P6T6 WS Revolution http://www.newegg.com/Product/Product.aspx?Item=N82E16813131358
Asus Web site - http://www.asus.com/Product.aspx?P_ID=WqMFKNkS6ZjDLx4S
CASE: $180
Antec 1200 Black Steel
120mm Fans 3 x 120mm blue LED front fan
2 x 120mm blue LED rear fan
200mm Fans 1 x 200mm top fan
Plus 2 additional Optional Fans x $14 =$28
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
http://www.antec.com/us/productDetails.php?ProdID=15120
POWER SUPPLY: $140
CORSAIR CMPSU-850TX 70amps on a single 12v rail.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
http://www.corsair.com/
Below is the rest of my planned build.
CPU: $280
Intel Core i7 920 NewEgg Price and Info
Plan on over clocking to around 3.66 depending on temps.
Video Card: $260
ASUS EAH4890/HTDI/1GD5 Radeon HD 4890 1GB NewEgg Price and Info
4890 home page
I decided to lower total cost versus dual card performance. So I could what for the wait until the Direct 11 Video Cards are released.
CPU cooler: $32
Scythe MUGEN-2 SCMG-2000 120mm Newegg Price and Info
http://scythe-usa.com.
Very quiet and very effective cooler, may add a second fan in a push / pull arrangement.
Thermal Compound: $18.
Arctic Silver 5 Thermal Compound NewEgg Price and Info
Is there a better one to use? Is this worth the price?
I just picked this one based on review comments at New Egg.
Mobo: $370
ASUS P6T6 WS Revolution Newegg price info
Asus Web site
Will over clock and want the future expandability. SAS option for later.
CASE: $180 Plus (2 Fans x $14 =$28)
Antec Twelve Hundred Black Steel
Manufacturer Product Page
ATX Full Tower Computer Case
Will it power all 6 Fans?
Do I need extra cable extensions for the fans / HDD, etc..
I Plan on adding Two (2) Scythe GentleTyphoon D1225C12B4AP-14
120mm Case Fans NewEgg Price and Info
$8. MOBO PWR cable extension
Idea is more fans but using them all with lower speed settings to reduce total noise without losing cooling.
POWER SUPPLY: $140
CORSAIR CMPSU-850TX NewEgg Price and Info
Extra long cables support full tower size chassis.
TX850W Dimension: 5.9"(W) x 3.4"(H) X 6.3"(L);”
Memory: $105 minus $20 rebate = $85
OCZ Platinum 6GB (3 x 2GB) NewEgg Price and Info
240-Pin DDR3 1600 7-7-7-24 CAS Latency: 7
Manufacturer Product Page OCZ3P1600LV6GK
Hard Drive(s): (Operating System / Apps) $230 x2 $460 for RAID 0
Western Digital VelociRaptor WD3000HLFS 300GB
10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
NewEGG Price and INFO
NEED DEDICATED COOLING FAN for these drives…? (antec 1200 has fans directly infront of the disk drives.)
Use the Rubber grommets around the hold down screws to minimize vibration / transfer.
Hard Drive (Storage) – $110
Western Digital Caviar Black WD1001FALS 1TB
7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
NewEGG Price and Info
DVD Drive - $29
ASUS Black 22X DVD+R 8X DVD+RW 12X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD- ROM 2MB Cache SATA 22X DVD Burner with LightScribe
New Egg Price and INFO
BLUE RAY / HD DVD- ROM Burner - $109.99
LG Black 6X BD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal
Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner Model GGC-H20L - Retail
Mobo: $370
CASE: $180
POWER SUPPLY: $140
CPU: $280
Video Card: $260
4890 home page
CPU cooler: $32
Mobo: $370
Asus Web site
POWER SUPPLY: $140
DVD Drive - $29
