Tom's Hardware > Forum > CPU & Components > Sound Cards > Can't find Realtek, front panel jacks won't work
Forum CPU & Components : Sound Cards - Can't find Realtek, front panel jacks won't work
For some reason my front panel audio jacks are not working today. I opened the case to make sure everything is plugged in the way it should be and there did not appear to be any problems there. When I plug the headphones in, normally a couple of Realtek screens pop up telling me that I have just plugged something into a jack. That not only is not happening, but I can't seem to find a Realtek icon anywhere. I opened the device manager, and it says Realtek is enabled and that the drivers are the most up to date ones.
When I plug in the phones, there is no sound coming from them and the speakers don't mute.
I'm running Windows 7 RC, and my two month old system has until now been very stable.
Any ideas?
Sponsored Links
Try re-installing the audio drivers for your MB. I did some windows updates on my system, and lost all sound. Had to reinstall all of the Realtek drivers from the MB CD.
Reply to cmichael138
I just did that. Now I do have Realtek in my system tray, however, the front jacks still do not work. Realtek does not even seem to recognize it when I plug in a jack.
I wonder if there's something physically with the hardware? It's an Antec NSK6580B case. The usb ports right below the audio jacks work fine.
I was having intermittent problems about a month ago where Realtek kept popping up saying it had sensed that I had plugged something into a jack even though I hadn't touched anything.
Reply to ditto1958
Well, I fixed it somehow. Went in the case and unplugged and re-plugged everything. I don't know why my Realtek disappeared, but once I got it back that still didn't fix it. I think maybe something was loose inside.
In the process I discovered that I had never plugged in the connector for the power button led for my case.
Reply to ditto1958
Nice to have simple, inexpensive solutions.
There are 1041 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
