Hi all,
First time I turned it on, it failed to turn on but a couple of seconds after, it turned on and everything was fine.
OC to 4Ghz, and tightened RAM to 8-8-8-24 1600 (it's the RAM native specs, but needed to do it manually because intel reads up to 1333).
Did some stress with Prime 95 and Sandra, no errors whatsoever.
But while installing programs, I needed to reboot, and sometimes it fails to boot, like the first time. When it boots though, it runs fine.. Until recently while figuring this out, it turns off in the middle of stressing with Prime 95 a couple of time.
So I used BIOS factory setting, no OC, no RAM tweaks, but sometimes it still fails to boot the first time, sometimes even fails the second and third time, but then it turns on (PC doing it automatically without me pressing the power button)
I thought it could be my PSU not having enough power, so I disconnected both HDD fans, the WD Caviar HDD, and the USB PCI port. But it still do the fail boot thing.
Please help me!!!
My rig consists of:
Corsair HX 650
Gigabyte P67-UD5 (BIOS F6)
i5 2500K
1 x Scythe Slip 1200RPM Stream 14mm.
3 x Scythe Gentle Typhoon 1850RPM 120mm
1 x Case Fan 14cm
RipjawsX 8Gb(2x4) 1600 8-8-8-24
Gigabyte GTX 460 Super Overclock
Crucial C300 128GB
WD Caviar Green 1TB
Samsung 7200rpm 500Gb
2x Akasa HDD Cooler 2 fans @ 4500 RPM
Netgear RangeMax WPN311 Wireless PCI Adapter
Belkin USB 2.0 Hi-Speed 5-Port PCI Card
1 x Optical Drive
Thank you in advance people..
Please help me!!!
My rig consists of:
Corsair HX 650
i5 2500K
1 x Case Fan 14cm
Crucial C300 128GB
WD Caviar Green 1TB
1 x Optical Drive
