Mb power connector
Forum Motherboards & Memory : Elitegroup - Mb power connector
I wanna buy the GIGABYTE MA785GM-US2H mb and it has an 8-pin CPU power connector. is that a requirement for the computer to work? cuz if it is, im buying a psu which doesnt have one. instead, it has a p4 MB connector. will that work on my mobo? thanks PS: im planning on using an AMD Athlon II X2 245 @ 2.9 Ghz.
Message edited by Anonymous on 10-18-2009 at 03:46:55 AM
Sponsored Links
what? did you leave out some words?
Reply to rand_79
if you psu just has a 4 pin mb power lead it plugs in to the 8 pin socket and will run ok .
Reply to Outlander_04
- 0 +
Translation?
after reading the reply I'm thinking he means he has a power supply with a 4 pin connector and wants to buy a motherboard with an 8pin if he can?
im buying a mb which doesnt have one. instead, it has a p4 MB connector. will that
work on my mobo???
the answer is yes, unless your power supply is really old then It might not have enough 12volt output.
Reply to rand_79
Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > Mb power connector
There are 1305 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
