Tom's Hardware > Forum > Motherboards & Memory > Asus > Chassis jumper disable still getting chassis intrusion
Forum Motherboards & Memory : Asus - Chassis jumper disable still getting chassis intrusion
I have a p5k3 deluxe mobo. The jumper to disable chassis intrusion feature is installed, I even replaced the jumper to make sure it isnt bad. When I clear cmos I can boot up fine, then the next time I boot I get the same error. This feature should even be working. Is this is MOBO problem or is there any other way around this feature?
Sponsored Links
In BIOS, disable chassis intrusion if available.
------------------------------ "To better understand why you need a personal computer, let's take a look at the pathetic mess you call your life."
Reply to badge
So what happens if you leave the jumper off?
Like badge said, chk the BIOS. My MB has the ability to turn the feature off - And I haven't had the cover on my case in 10 yrs.
------------------------------ Gigabyte MA785GM-US2H, AMD Phenom II x2 550 BE (4 cores@3.6GHz), G.Skill 2x2GB DDR2 1066 (820@CL4), Scythe Katana3, Hec 585W, Samsung 2232BW+, WD Caviar Black 1TB SATA, Sea 500GB USB, 12 IDE HDs w/Masscool IDE-SATA Convertors, Ugly Old Case, Win XP 32bit
Reply to mongox
There are 1173 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
