Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > How-to capture and post images to the forum...
Forum Motherboards & Memory : Gigabyte - How-to capture and post images to the forum...
See Dick and Jane Capture and Post a Screen Image to the Forum: an image posting primer! :bounce:
To 'capture' application screens, you click on them so they are the 'active window', then hit the <ALT><Prt Scr> combination (anther handy one is <CTRL><Prt Scr> - captures the whole desktop image...), which puts the screen image onto the clipboard; then, open Paint (or any other graphics program you're familiar with) and either do Edit/Paste, or a <CTRL><V>, to paste the image; save it with a File/SaveAs with the Jpeg file type selected (.JPG), and you'll be ready to post it.
To post the images, the first thing you want to do is go to ImageShack: http://imageshack.us/
and create an account (it's FREE) for yourself (and save a bookmark - I use it so often, that I keep the shortcut to it on my desktop - but then I've got a lot of desktop [four monitors worth - :love: ]); there are any number of these file and picture 'sharing' services (I use MediaFire for sharing files like BIOS and drivers here...), but ImageShack seems to have a minimum of intrusive crappola, and seems to dependably 'keep' your files; if you want to use a different one, this should give you a pretty good general idea of 'what to do'...
Once you're registered, going to the site will 'pop' this screen:
http://img41.imageshack.us/img41/7635/0119w.jpg
Click on the 'Browse...' button, and find your image file; once you've selected it, a click on the orange outlined 'start upload!' button will get it up there, and it will go to this screen:
http://img197.imageshack.us/img197/3364/0120i.jpg
Click in the window labelled 'Hotlink for forums (1)' (encirled in green in the illustration...), and copy & paste it to your post - it will look like this:
{URL=http://img41.imageshack.us/i/0119w.jpg/}{IMG}http://img41.imageshack.us/img41/7635/0119w.jpg{/IMG}{/URL}
(I have replaced the square braces with curly ones, just for illustration; otherwise you'd not see the line, just the underlying picture!)
Then, if you want to post another picture, click on the (red encircled) 'Upload another image' item, which will return you to the first screen -
-and that's it!
Another thing that will work, is to only copy the part in green:
and paste it to your post...
Yet another way, is to only copy this part in green:
and click on the 'picture thingie' atop the posting window:
http://img17.imageshack.us/img17/8144/0121kl.jpg
which will 'pop' this window:
http://img18.imageshack.us/img18/6025/0122nb.jpg
where you simply paste on top of the 'undefined', and click OK. To use this method, however, requires that you enable 'scripted controls' in IE:
Click your way 'in' to InternetExplorer - Tools-> InternetOptions-> 'Security tab':
http://img98.imageshack.us/img98/6982/0123h.jpg
Click on 'Custom Level':
http://img17.imageshack.us/img17/5113/0124vl.jpg
scroll down to "Allow websites to prompt for information using scripted windows", and click 'Enable' - then 'OK' and save the settings... A little more difficult, but a little more elegant :sol:
Message edited by bilbat on 10-18-2009 at 10:16:12 PM
Sponsored Links
Hey, great post bilbat!
If you leave a space between the brackts [img] http://www.blah.com/sample.jpg[/img] it won't post either.
So which of the hosting sites will allow you to upload with ftp? I always use my RoadRunner webspace for stuff, you can reserve space for each email alias you have, thereby getting tons of space. They have two free types of webspace, one with 5MBs I think, the other with 10. The 5MBs is easier to use.
------------------------------ Gigabyte MA785GM-US2H, AMD Phenom II x2 550 BE (4 cores@3.6GHz), G.Skill 2x2GB DDR2 1066 (820@CL4), Scythe Katana3, Hec 585W, Samsung 2232BW+, WD Caviar Black 1TB SATA, Sea 500GB USB, 12 IDE HDs w/Masscool IDE-SATA Convertors, Ugly Old Case, Win XP 32bit
Reply to mongox
...............................TEST.................................
http://img9.imageshack.us/img9/5600/20091020101335.th.jpg
Reply to rsetter1
On an image that size, this works better
http://img9.imageshack.us/img9/5600/20091020101335.jpg
Reply to mongox
I agree, but how did you do that?
Message edited by rsetter1 on 10-20-2009 at 07:46:45 PM
Reply to rsetter1
You posted this URL:
http://img9.imageshack.us/img9/560 [...] 335.th.jpg
I posted this URL:
Note the .th. at the end of yours. You got the url from the thumbnail (th) of the image but I got it from the full-size image. Just need to copy the right image location.
See on the lower right-hand side of you image page, it shows both Image URLs and Thumbnail URLs.
Reply to mongox
Thanks again Bilbat, mongox too.
I think I've got it!
http://img12.imageshack.us/img12/4543/20091020192735.png
http://img43.imageshack.us/img43/7499/20091020193705.png
http://img21.imageshack.us/img21/1228/20091020194831.png
Message edited by rsetter1 on 10-21-2009 at 04:54:40 AM
Reply to rsetter1
There are 782 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
