Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > TV Tuner Cards > Will this LCD Desk Mount Work With HP w2228h?
Forum Graphics & Displays : TV Tuner Cards Will this LCD Desk Mount Work With HP w2228h?
http://h20000.www2.hp.com/bc/docs/support/SupportDocument/c01480218/c01489686.jpg
http://ak.buy.com/db_assets/screen_shot_images/401/10398401_004.jpg
Ok, so I know my display (an HP w2228h) supports the standard mount.
So... I want to use this swing-arm mount with it. Will this work? Are there any alternative desk LCD mounts I should know about?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
The monitor is VESA compliant, as well as the desk mount, however the weight of the monitor is beyond the maximum weight capacity of the desk mount arm. Monitor= 9Kg or 19.8Lbs. Max of desk mount arm= 18Lbs....
Reply to shabaa
- 0 +
Damn it... ah well, I just realized a swing arm mount might be too fancy for my needs. Was attracted by it's totally cool factor :P
Anyways, I decided to settle on this desk stand instead. If there's one thing I don't like about my display, it's that its stand is a bit too bulky.
Reply to r_manic
There are 1839 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help appreciated
By 2fast4thetown_down, 4 hours ago:
If you have a 400 or more psu you should be fine it seems to be compatable just look at...
Best offers
Top experts
