Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Is the problem from GPU or CPU?
Forum Graphic & Displays : Graphics Cards - Is the problem from GPU or CPU?
Hi
I bought EVGA GeForce 9800 GTX+.
I tested it by 3DMark Vantage.
And here the results:
GPU Score: 4607
CPU Score: 24414
I think gpu score is low, am i right?
I tested crysis and it was little slow on very high (lag) and it suppose to work on very high without problems with 9800 gtx+.
My computer's specification:
Core 2 Duo E4500 2.20 GHz 2 Mb
GIGABYTE GA-P35-DS3L
Ram 2 GB DDR2 800
2* Western Digital 160 GB 7200 rpm cache 2 MB
HKC USP 500 (500 watt)
LG LCD Monitor M2294A 22inch 1680X1050
Windows Vista Home Premium
CPU's Temperature: 37 degree
GPU's Temperature: 50 degree
What is the problem?
Is the problem from gpu?
or do i need to upgrade my cpu?
Thanks
Sponsored Links
Your CPU is the bottleneck.
You'll get much better scores if you overclock your CPU to 2.93 Ghz (11 multiplier X 266 fsb). The faster bus will boost your scores by around 15% if not more.
Reply to HundredIslandsBoy
- 0 +
CPU's Temp is between 37 - 40
I don't think I can overclock my processor with this Temperature
Maybe i should buy a better processor
What do you think of Core 2 Duo E8400? is it good with games?
and do you think i should upgrade my ram to 4 GB? or 2 GB is enough?
Thanks
Reply to HNH992
- 0 +
If you mean 37-40C at full load, you can go beyond 3GHz. If you don't worry too much about CPU life.
------------------------------ Intel Core 2 Quad Q6600 @ 2.4 | Thermalright Ultima 90 120mm fan | Intel DG31PR | 4 GB DDR2 @ 800MHz | HD 4850 512 GDDR3 | Corsair VX450 | Samsung 22x DVD RW | Windows Vista HP 32-bit/ Windows 7 64-bit dual boot | Samsung SyncMaster 19" LCD VGA 920NW |
Reply to rags_20
- 0 +
I mean 37-40 when the computer is idle.
Reply to HNH992
- 0 +
I downloaded Orthos Prime and Core Temp.
then i ran Orthos and I started it with one core.
after 20 minutes the temperature was 63.
can i overclock it?
Reply to HNH992
A $119 Core 2 Duo E7400 would be a relatively cheap upgrade from the cpu you have now and would perform way better: http://www.newegg.com/Product/Prod [...] 6819115206
Reply to edeawillrule
There are 916 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
