CPU problem
when power on the CPU beeps every after second
3 answers Last reply
More about problem
  1. CPUs don't beep, system unit speakers or motherboard speakers beep! :non:
    If you mean a continuous series of beeps, could be memory problem. You need to give FAR more information about your system and its history if yo want a better answer. If you have just bought it, take/send it back under warranty.
    Mike.
  2. You need to look at your motherboard manual. If you can't find the answer there then contact the company.
  3. lol a cpu is a part of the system, if you dont know that then i suggest take your "CPU" to a repair center
CPUs Power Components
