External hd problem
cyrain
5
Hello,
i have a 250gb WD external HD. few days ago my cousin wanted to take backup of his file as he was upgrading to snow leopard in mac. he formatted that hd in mac and setup time machine in that. after finishing he gave it back up it is not being detected in windows... but if connected to mac its detecting it properly not in windows... what to do about this problem???
help pls
regards,
cyrain
Macs format HDDs in a different filesystem, I think it is Ext2 or Ext3, something like that. Windows does not read this filesystem, it needs NTFS or FAT.
What to do? You can have your cousin partition the HDD on his machine, and put his mac files on a partition, also name that partition so it can be recognized later. Then he can format the other partition as NTFS (also rename it) and when you will plug that in a Windows PC it will see the NTFS partition and it will be able to access it. The other one will stay as it is, with his back-up files on it.
