I really like the performance of these cases but was wondering where you buy the fans to replace the 230 and 200mm fans when they die. Also I want to make them blue instead of red. I searched newegg, tigerdirect, Micro Center, Diretron, xocide for the fans and didn't see them.
Is it the same 230mm fan that they use in the HAF932?
I personally like the HAF922 looks better so I would like to work with that and get blue fans on the front and side and the best fan solution on the top.
I'm sure it will fit because it's made by cooler master and has the same dimensions. Be aware that you can install four 80mm or 90mm fans on that side panel.
Message edited by krjcook on 08-06-2009 at 12:17:52 AM
If is HAF932 the side panel will fit 4x120mm fans and 3x120mm fans on the top
I used the casing for almost a year now and the fan is still running perfect lol
I was talking about the HAF922 not the HAF932 maybe that is where the confusion was. I really don't like the look of the HAF932.
Me neither seems that they tried to hard on that rugged/military look, rather choose the cosmo S, cooler master scout, raidmax monster, or 1 of lian li's many cases.
Message edited by krjcook on 08-07-2009 at 12:56:02 AM
