Yes No
Ads
Temp. Monitoring HELP
Forum Overclocking : Heatsinks & Air Cooling Temp. Monitoring HELP
Ok so I just completed my new build and I am having so slight software issues with monitoring temps. Speedfan has become useless since upgrading. So which other programs are reliable for system monitoring. My build consists of:
ASUS M4A89GTD-PRO (BIOS.- AMI 1606)
X4 965@3.4GHz w/ Titan Fenrir HSF
DDR3 1600 CAS 9
ATI 6870 @ 900/1050 MHz
60GB SSD
640GB HDD
550-watt 80+ Gold PSU
Win. 7 64-bit
I am seeing some really strange readings from Speedfan like Fan RPM of 16 RPM...Temps seem right as I have used PC Wizard to check also AOD, OCCT, and any other program that could check temps. I just like programs like speedfan, as they are more convienant to run than the aforementioned programs. Anyone know of a fix for this problem with Speedfan on this set-up? Even better does anyone know of any other utility that monitors temps and fan speed in real-time?
------------------------------ http://valid.canardpc.com/cache/banner/1921079.png
Reply to lowjack989
Well for me, the best temps monitoring tools would be Hw monitor and second choice Everest. You cant go wrong with any of them. I also had issues with speedfan..
Reply to 55Range
I personally like RealTemp and CoreTemp.
------------------------------ Watercooling Info:
Tom's Hardware Watercooling Sticky
Build Log | Project: Askew
Stuff 4 Sale
Reply to rubix_1011
Hw monitor pro more accurate
Reply to henydiah
RealTemp, CoreTemp, Hw monitor, Everest - all of them are accurate :)
Reply to oc_mania
Tom's Hardware > Forum > Overclocking > Heatsinks & Air Cooling > Temp. Monitoring HELP
There are 1914 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 14 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
