Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > [Solved] New system build problem
Best answer from BigFysh3.
Need help with new build. When I powered up the first time, fans and lights come on, but no post beep, no video, cpu cooler fan not blowing. Removed video card, 1 stick ram, no change. What am I missing?
gigabyte ep45-ud3p
e5200
his radeon 4850
corsair tx650w
g.skill4gb ddr2-1100
artic cooling freezer
May want to check to see if the 4Pin connector is connected to the motherboard. May also want to check to make sure that it is not grounded out on the case.
Sponsored Links
Best answer
Reply to BigFysh3
After my post, I decide to started over again and found that I had neglected to connect the 2x4 pin power connector. Smooth sailing after I hooked it up.
Reply to teleman
That's usually what happens.
Reply to jsc
There are 1056 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
