Replacement mainboard, opinions
Hey there!
Apparently my mainboard is making some trouble (http://www.tomshardware.co.uk/forum/page-273027_13_0.html) and I'm looking to replace it.
I was thinking of buying this as I've only read good things about it and a friend recommended it after having installed two of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128368
This is my current setup:
XFX 512 GTS 250
Intel Q9550 775 2833 BOX1333 12M
Corsair CMPSU-520HX 520W ATX2
Asus P5Q-Pro P45
Corsair 4GB 1066-555 Dual Channel
Do you think it's a good choice or should I rather get something else? (Price doesn't matter.)
4 answers Last reply
More about replacement mainboard opinions
  1. Have you tried ubuntu 9.04 yet? It has detected all the devices in several of my boards so far. I ordered it and also burned a free copy. You can also try a bios update at your own risk. I have used asrock p45 and g43 boards; they work well but are less successful at overclocking. I like to save money. You should also list your problems before ordering a new board, which may require a format and fresh install of your programs. This forum and anandtech are pretty good with helping.
  2. gkay09 said:
    Thanks for your input! Guess I'll be getting one of these then, thanks.
    Thanks for the suggestions but I've been trying to determine the cause of my problems for about 2 months now. I've posted on different forums and tried everything I possibly could. I've formatted entirely, several times, tried different distros (including Ubuntu, I run Linux exclusively), different desktop environments, different setups and different software sets. I've run all the diagnostics/stress tests one should run, several times. I've checked my temps several times with different utilities and even manually as best I could. I've tried all RAM slots etc etc. Now I am pretty certain that it must be my mainboard and everyone else agrees, though one can't be 100% in my case as it would seem. This is pretty much the end of the line.
  3. I have a UD3L. Good board.
    If you know you are not going to CrossFire, you do not need the UD3R. Save $20.
Motherboards Corsair
