Tom's Hardware > Forum > CPU & Components > CPUs > HELP! No signal from CPU to monitor
Well I have a compaq presario SR2034NX
here r the cpu specs:
http://h10025.www1.hp.com/ewfrf/wc [...] ct=3250941
Heres the problemo:
Well so a few days ago I turn on my computer, only to find out that nothing would show on the monitor. The light on the monitor remains orange instead of green. So I figured its the monitor (i'v had problems with it in the past) and hood up my old CRT monitor to make sure its the monitor.
But the crt montor does the same thing. The light remains orange. Then i decided to open it up and see if i can pull out the video card and put it back in, i thought it would solve the problem.
But after looking for the video card, I realize that there is no video card, atleast not it in slot its supposed to be in. So now i'm supposing I have integrated graphics.
Anyway, can someone help me out here? what do you think is the problem?
I'm thinking of going out and buyin a cheap video card and try to see if that solves the problem?
Sponsored Links
If you have no display ,,then you can't possibly check the bios to see if the onboard is even on or whatever,AND if you are going to get an add in video card,,might it not make sense to get a good one thus delivering you from that problem once and for all???..:)
------------------------------ When you obsess on your enemy,,
You become The Enemy...
Reply to dokk2
what exactly do you mean by a "good" one? i thought they were all "good"?
Reply to jadi929
How much money are you willing to spend on the graphics card and what interface does your motherboard support (AGP or PCIe)
------------------------------ | Intel C2Q 6600 | MSI P35 Platinum Combo | 4GB DDR2 800 Kingston HyperX | XFX 8800GTS 320MB | Antec 900 | Raidmax 630W Modular PSU |
Reply to aoster87
You don't know yet what is cause of this. It might be the processor, ram or motherboard.
I suggest you take out the ram and see if the motherboard is "beeping".
------------------------------ Intel i7 920, Gigabyte X58-DS4, 3x1 Corsair DDR3 1333, XFX 260 GTX
Samsung 750Gb F1,Samsung DVD-rw, Hiper Type-M 880W, Coolermaster HAF 932, Logitech Z-5500
Reply to hefox
If you have the money, just buy a new one.
------------------------------ AMD Phenom X3 8450|eVGA nForce 730a|eVGA GTX 260 SC| Corsair DDR2800 2GBx2|Acer19" and HP 21" Dual| n52te Gamerpad
Reply to JDV28
hello and welcome to the best fta site on the net. We are glad you are here and hope you enjoy this great site. Thanks for being here.
[color=#FFFFFF]comparatif simulation taux credit auto[/color][color=#FFFFFF]- Taux crédit auto. Comparatif des offres! Les meilleurs taux crédit auto sont sur le net ![/color][color=#FFFFFF]comparatif simulation taux credit auto[/color]
Reply to plazake
Buy what? PC, motherboard, ram,etc?
First is better to find out what might be broken and then start changing parts.
Reply to hefox
There are 1259 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
