Hi,
I am having problems transferring files to my microSDHC card via my USB card reader.
It copies for 1 second and just stops. When I click cancel, it'll take forever to cancel and I will have to plug the USB card reader out for the "cancelling" window to close.
This happens on my computer that's running on Windows 7. This is a computer I built myself. It's using M4A79 Deluxe motherboard. I've updated the BIOS to make sure I cancel out any USB compatibility issue with Windows 7.
I've also tried every port and it doesn't work.
Transferring files to USB thumbdrives and hard drives is alright though.
My laptop running XP has no problems transferring to the SD card via the same card reader.
Is it a USB hardware issue? Or Windows 7 has problems with the USB card reader and the card?
Thanks for the help in advance!
