Need help on my first water rig
I'm planning on building water cooling rig and I have begginner questions
Since this is my first I don't want to spend more than $200 on the water cooling parts so if I mess up I don't lose THAT much.
So I plan on getting the XSPC Rasa 750 RS360 kit and the reason for getting a kit is that I don't want to get incompatible stuff on accident.
The rest of my specs are:
Phenom x6 1090t
2x2gb ocz gold ddr3 2000
CORSAIR CMPSU-750TX
ASUS M4A87TD/USB3
Cooler Master Haf 932
Western Digital Black 1TB 64MB Cache
Power Color Radeon HD 6850
Heres my questions
1. What coolant should I use Feser One or Distilled Water
2. If I get distilled water should I use PT Nuke or a silver coil or something else entirely
3. Is it ok to use dyes in distilled water or will mess up things like I've read cause I really like the Feser UV Red Dye
4. Is there any maitenence involved in water cooling such as refilling or something and how often should I refill
After googling for a while I have that you should refill like once a year and the best coolant is distilled water with a silver coil and dyes will mess up everything but I kinda want to have conformation before I buy everything
All advice is greatly appreciated,
Austin
More about : water rig
Quote:
Heres my questions
1. distilled only
2. Yes and yes to distilled/killcoil. Kill coil can be optional.
3. No. But, use at your own risk.
4. 6-9 months is often recommended. See the links in my signature for a ton of WC info.
Edit: Added link for your Feser1 stuff: http://www.xtremesystems.org/forums/showthread.php?p=3837299
1- Or di-onized water
2- IMO kill coils isn't an option, you need that in your loop
3- No, that damage your loop components in little steps and many manufacturer don't apply warranty if you use dyes.
4- Here is where you need the silver KillCoils, with that you avoid many of those things living in your loop and in the same way the maintenance time isn't as frequently.
Related ressources
The PHN is the most commonly used kind. It's developed for straight distilled loops to keep the PH in the water balanced.
It mentions the specific use of each in the description/link on Petra's web site.
rocky_1 said:
Thanks
so I'll pt nuke -PHN
and distilled water no dyes
wish I could give you guys both the best answer
if you plan on using EK acrylic res. stay away prom PT nuke,specially PHN
it will void you warranty if it cracks
I personally avoid dyes as they are messy and annoying. If you want color, get colored tubing. Primoflex LRT comes in many colors and is quite cheap.
Ask the community
