Hello everybody,
I'll be thankful to anybody who can help me.
Problem: under SUSE, filesystem gets automatically in read-only modus + CPU saturated. System hangs when it turns to the screensaver, cannot log-in anymore. HD (in RAID05) already checked, seems not to be the problem.
Maybe MEMORY.
getting >this error< with the firmware test provided on the SUSE-Install.CD
>Here< the options I can modify in my PhoenixbiosBIOS
Many thanks for help!
Alex
SYSTEM-INFO:
Xeon dual core 64bits
Intel(R) Xeon(R) CPU 5160 @ 3.00GHz
Raid controller Adaptec 2820SA
HD: 6x 250 Gb SATA2
IDE: 1*2 UDMA 100
MB: Supermicro X7DA8
Memory details
# dmidecode 2.9
SMBIOS 2.4 present.
Handle 0x0018, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0017
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank1
Type: DDR2
Type Detail: Synchronous
Speed: 533 MHz (1.9 ns)
Manufacturer: Not Specified
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0019, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank2
Type: DDR2
Handle 0x001A, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank3
Type: DDR2
Handle 0x001B, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank4
Type: DDR2
Maybe MEMORY.
Alex
SYSTEM-INFO:
HD: 6x 250 Gb SATA2
IDE: 1*2 UDMA 100
Memory details
# dmidecode 2.9
SMBIOS 2.4 present.
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank1
Type: DDR2
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank2
Type: DDR2
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank3
Type: DDR2
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank4
Type: DDR2
