Solved
Will the CM Hyper 212+ fit in a Thermaltake Armor+ MX case?
I've been wanting to OC my Intel Core i5 750 so I'm looking to buy a Cooler Master Hyper 212+ cooler for it. My question, will it fit in my case? Has anyone else tried it in my case?
Thanks,
Tony
4 answers Last reply Best Answer
More about will hyper thermaltake armor case
  1. Best answer
    Yes it will fit without removing the side fan.
    Your case is 9.44" wide.
    The 212+ is 6.24" tall so there's plenty of room.
  2. Best answer selected by tonysathre.
  3. Thanks a lot man.
  4. It's a great cooler, I just got mine earlier this month.
    My HAF 912 is 9.1" wide, and my 212+ has about 1/2 an inch of room IF it was behind my lone side fan, fortunately the fan sites below the 212+.
    Anyway, Davcon is correct, with 9.44" of room and your side fan is only 20mm thick(vs 25mm for mine) you should have plenty of room.
Heatsinks Cooler Master Cases Intel i5 Thermaltake Overclocking
