Hi guys, this is actually a two part question. I was originally going to post just for help with trying to overcome a wall it feels like I hit at around 3.7-3.8Ghz, but now there seems to be a problem that I'd like solved first beforehand.
I am a novice overclocker and this is my first system, but I have been reading many forums and been trying to comprehend everything so far. More importantly:
AMD Phenom II X6 1055t
Asus M4A89GTD 890G Pro/Usb3
CoolerMaster Hyper 212 Plus HSF (Idle runs from 28*C to 36*C depending on Ghz)
G.SKILL Ripjaw 8GB (4 x 2GB, bought 2 pairs) DDR3 1600 (PC3 12800) F3-12800CL9D-4GBRLHere
SeaSonic 620W 80 PLUS BRONZE Certified Modular Active Here
I have been running many different settings over the last two days, for hours. I started working the Vcore down with everything else @ stock to see how low it would go before it wouldn't run at 2.8Ghz anymore. I did a total of 5-6 tests, each time taking the max Vcore it took in HWmonitor and then setting the Vcore in BIOS to that setting. Each time, I noticed I had a Vdroop of around -0.06V while running IntelBurnTest, so setting at 1.344V would actually run down to 1.28-1.308V, setting to 1.308V it would run at 1.248-1.26V, etc. In all the tests, the idle would be the number I set in the BIOS, while running Intel would cause the Vdroop.
Now, that didn't and still doesn't seem bad to me since when running all cores @ 100% it would only run at 41*C and not overvolt the system.
So, I started with the lowest setting I found I could run 2.8Ghz (between 1.2V-1.26V) and began working the Bus Freq up.
Eventually I got up to 250Mhz, in which I had to increase Vcore to around 1.3125 and set my DRAM timings to 8-8-8-24 (if I remember right, it wouldn't boot without tightening the timings, something I had never tried before), 8x and 5.33x multis (i.e.NB & HT 2000 and DRAM 1332.5), and if I remember right I had either disabled C1E, Cool n' Quiet, Turbo, EuP, and both Spreads, and Secure VM by now or had done so in the beginning with the 2.8Ghz tests.
From there, I got 255Mhz by bumping Vcore to 1.33125V.
And from there, I went to 260-265Mhz, which is where I started encountering many BSODs and problems, which will be my second question after we get THIS resolved:
When trying to achieve a stable 3.6-3.8Ghz-ish build, I noticed I no longer had a -0.06V vdroop, but instead it would run idle anywhere from +0.001V to 0.035V (i.e. 1.425V would hover around 1.46V) over the Vcore BIOS setting I used. Now every time I change the Vcore, even to the settings I had tested when I was getting the Vdroop, I still get an overvolt (running at 1.26V in BIOS while HWmonitor/CPU-Z says I have 1.272 idle, which will actually increase HIGHER when doing IntelBurnTest).
To get my point and question across, all of a sudden it seemed like when I hit around 3.5Ghz and started to actually adjust voltages and DRAM timings, my Vcore would instead overvolt and go over my bios setting, even at idle. Now it won't even go back to having the Vdroop, though I am positive it would if I did a CMOS reset.
If I remember right, the overvolting seemed to occur when I adjusted VDDA to around 2.5-2.55v, and I've heard the VDDA is used for stability because it increases the Vcore to allow more voltage in case it needs it (i.e. for stability). If this is directly related to the overvolting occurring, I don't see why setting VDDA back to auto wouldn't solve it...
So, if someone can help me with this problem first, I'll be able to address the original meaning of this thread.
Ask for any additional information and I'll try to provide it. I've never used Prime95, since it seems like a large waste of time compared to a fast and intense 2-10 minutes under IntelBurnTest.
Anyways, thanks in advance guys. Would really like to be able to at LEAST reach a stable 3.8Ghz, and this is proving difficult.
