Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > New motherboard. System starts up, POSTs, then restarts.
Forum Motherboards & Memory : General Motherboard - New motherboard. System starts up, POSTs, then restarts.
So I just swapped out the motherboard in my working system for a new BIOSTAR G31E-M7 (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262), and now I can't seem to get it to work. I successfully flashed the latest BIOS, and I can get into the BIOS (I already set it to default settings and reset the CMOS jumper), but I can't get much further. I get to the screen where you can choose how to start Windows (I'm using XP), but whatever I choose the system just resets. Nothing spins down or shuts up, it just restarts my machine. I swapped out the CPU and memory, but the same thing happens, and since the system was working until the mobo swap, I feel I must have overlooked something. Help?
Specs:
730 Watt Raidmax PSU
Intel Q6600
2 x 2GB DDR2 800
Haven't even seated my video card yet.
Thanks.
Sponsored Links
That's what newer windows operating systems do when you change boards. There's nothing wrong with your system. You need to format and do a fresh installation of windows, or (with your old board installed) start in safe mode, remove all the system devices, install your new board, go back to safe mode, install the new board drivers, and reboot. You may get lucky and avoid a format.
Message edited by o1die on 10-25-2009 at 07:33:13 PM
Reply to o1die
Thanks for the speedy advice. I'll try that and get back to you.
Reply to pullarius1
There are 526 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
