Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power draw specs overrated?
Forum Graphic & Displays : Graphics Cards - Power draw specs overrated?
why does the power draw specs on videocards overrated? 9800gt advertised needing 26amps. but in reality, it just needs around 12 amps. gtx260 advertised needing 36 amps but it just really needs around 19.. dont know the advertised rating of the 4850, but my cousin said it just needs around 10-12 amps also.
Sponsored Links
Well, they advertise the overall PSU power needed. Keep in mind the PSU is also powering other power hungry things. An overclocked quad could take up to 10 amps on your 12V (or even more in some cases), so their recommendations are meant to be good, safe overall system requirements.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Total system power requirements. Including hard drive, CPU, sound card, motherboard...
Power requirements are typically greater than what most people's system will draw. AMD and nVidia usually set higher specs as a safety margin and because they don't know what people have in their system.
Example: You and your friend wants to install a GTX 285 video card in your system. You have an Intel E8400, 2 hard drives, an average motherboard, and a DVD burner. Your friend has an Intel i7 940, 4 hard drives, a performance motherboard and two DVD burners. Guess who has higher power consumption before adding in the GTX 285?
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
why does the processor take power in the 12v raiL? isnt it supposed to be on a different rail?
isn't the 12v rail ~only~ for the gpu?
Reply to BruceOTB
Because it is reality.
Reply to jaguarskx
haha. what an answer. :)
afaik, 12v rail is for the gpu and peripherals (case fans). other stuff draw power from a different rail. i'm probably wrong at this, so if anyone wants to make things clearer for me, ..please. ;-)
Reply to BruceOTB
- 0 +
Look at the diagram for the MB plug. A ton of them are 12V. Also look at the aux CPU power plug. I believe all of those are 12V. I'm afraid the CPU/MB uses a lot of 12V, just as the peripherals use 12V and 3.3V and 5V. The fans do only use 12V.
------------------------------ New Build (Under Contruction): Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB > Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > Hyper 212 Plus > See other Builds in Member Config
Reply to EXT64
Just about everything runs off 12V now, completely or partially.
Reply to randomizer
oh.. so whats the use of the other rails then?
Reply to BruceOTB
- 0 +
Hard drives need 5V, and there are still a few other things that use 3.3V or 5V to some level.
Reply to cjl
mobo uses 3.3v & 5v
PCI cards draws from 5v
RAM draws from 3.3v
HDD & Optic drives draws from 12v & 5v
Floppy Drive (thought these died along with the dinosaurs) 3.3v
Reply to jaguarskx
There are 1181 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
